4-6 inch lift and towing - Ford Powerstroke Diesel Forum
Old 01-24-2008, 05:58 AM
Send a message via AIM to OrangeSS Send a message via Yahoo to OrangeSS
I own a 04 superduty 6 litre. i am thinking of putting on a lift. my question since i own this truck to pull my drag car. what are the draw backs on towing with this lift. i want to go with pro comp
Old 01-24-2008, 06:02 AM
Make sure and get leaf springs for the rear and not blocks.
Old 01-25-2008, 04:50 AM
If you own a 350 then it will be the same as mine.
Get 2" blocks from a F250 with 4" Pro-Comp rear springs.
This will raise the back about 2"
Get 6" front springs.
It will sit almost level.
With the 4" blocks in back it sat back end high and rode like a tank.
Or just get a 3-4" lift for the front and leave the back alone.
If you have a 250. The same minus you have the blocks already.
WIth the truck more level, it will ride better.
Old 01-25-2008, 05:24 AM
I beleive he wants to tow with it!!So if you level it the front will be high when towing and not steer as well!!!If you make sure it has a 2" rake it will tow alot better the truck will be more level with a load..
Old 01-27-2008, 10:36 AM
yes i am going to use this truck to tow
no i do not want to use blocks
i just want to know if i will loose any towing capacity and what are the good and bads of a 4-6 or even a 8 inch lift on a 04 super duty. its a short bed quad cab. if it matters its a harley davidson edition cause my truck stock seems like it sits higher than other 250s
