noises - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-22-2013, 06:14 PM Thread Starter
noises
Hello to all, when turning to left a full turn I hear noises from front .can someone tell me what it may be only when turning .Thanks
1BadBoy is offline
post #2 of 7 Old 03-22-2013, 06:22 PM
jesilvas's Avatar
Quoted: 2 Post(s)
4wd, 2wd, what year, what truck, more info.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 7 Old 03-22-2013, 07:44 PM Thread Starter
noises
08 f450 4x4 6.4
1BadBoy is offline
post #4 of 7 Old 03-22-2013, 07:55 PM
Turbostang500's Avatar
Gonna have to explain those noises chief.
Lee
2000 F250 PSD SCSB 4X4 418k miles straight pipe gauges 2" leveling kit 315/75r16's
6637 with custom intake pipe. TS Performance 6 position chip!
[/URL]
Please don't confuse my attitude with my personality.. my personality is who I am,my attitude depends on who you are...
Turbostang500 is offline
post #5 of 7 Old 03-22-2013, 08:25 PM Thread Starter
noises
Hello the noise sounds like it may b some thump thump when steering wheel is turning the right. How do I know if tie rod lower or upper ball joints center link are bad..
1BadBoy is offline
post #6 of 7 Old 03-22-2013, 08:35 PM
Jack the front end up off the ground and shake the tire or have someone else shake it both side to side (3 o'clock and 9 o'clock position) to check tie rods and up and down (6 and 12) for ball joints and wheel bearings. Sometimes a stout pry bar under the tire, between the tire and ground, and prying upward like your lifting the tire is a better way to check for ball joint play. Any joint that moves both laterally or separating is bad.
Lee
[/URL]
post #7 of 7 Old 03-23-2013, 06:42 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Or ujoints.
4R100, 2wd
330,000 + miles
jesilvas is offline
