Truck unlevel - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-14-2013, 03:46 PM Thread Starter
Truck unlevel
I've got a 03 7.3 with a 8in lift and 37s. Ever since I got into a little fender bender my truck has been uneven. The passenger side sits about a inch higher. I measure the exposed part of the shock and the driver side was 7in while the passenger side was about 8in. Could this be a shock problem or something more major say the spring?
liftedtrucks is offline
post #2 of 9 Old 03-14-2013, 06:29 PM
shawnb99's Avatar
i have seen STUCK ( BENT ) shocks, but usually the problem is elsewhere, most of the time the driver side sags first due to continuaal wieght loads, from driver and fuel.
04 F-250 CCSB 4X4 6.0L Auto, tweaked by GEARHEAD
follow link to truck for sale
shawnb99 is offline
post #3 of 9 Old 03-14-2013, 06:34 PM
Originally Posted by shawnb99 View Post
i have seen STUCK ( BENT ) shocks, but usually the problem is elsewhere, most of the time the driver side sags first due to continual wieght loads, from driver and fuel.
IS THAT A FAT JOKE!?!
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #4 of 9 Old 03-14-2013, 07:48 PM Thread Starter
Lol I'm 18, only 511 and 160 pounds so I don't think so! Should I just take the shocks off and see it it is still tilted?
post #5 of 9 Old 03-16-2013, 08:52 AM
shawnb99's Avatar
i doubt the shock will make any change....
fat joke ....no....but the driver side always see more weight than the passenger.
shawnb99 is offline
post #6 of 9 Old 03-16-2013, 09:02 AM
JJFLASH's Avatar
Quoted: 111 Post(s)
How much of a "fender bender" was it? What actually happened?
Sometimes doesn't take much to knock things around. Also, is it possible that it was always leaned but you never noticed it till you started checking things after your "fender bender"? One inch of sag isn't much.
-JJ-
Mine - 94.5 F250 ZF5: Basics w/a few extras, DIY bumper, steps and exhaust, AFEII, D60, PMF 2.25 RSK, V-codes
Hers - 04 GM 2500 CCSB 4x4: LB7, EFI Live by KW, 2" Lift, MBRP 4" dp back
RIP 15/08/23- 98 GM 1500 ECSB 4x4: 6.5, straight pipe, K+N filter, 495km w/original pump, trans & t-case
JJFLASH is offline
post #7 of 9 Old 03-17-2013, 06:17 PM Thread Starter
I ended up crushing a honda who slammed his brakes on a yellow light. His car was totaled and the only damage to mine was a crack in the grille, and a bent bumper. But now i have just noticed the lean. the lift it self only has 20,000 miles on it so id be pretty disappointed if the spring broke but i was in an accident so not sure. I might just go with some bigger springs and throw some bigger tires under it. what do you guys think?
post #8 of 9 Old 03-18-2013, 07:24 AM
ajordan6337's Avatar
Most lifts have warranties call them and tell them its uneven but dont tell them you hit anything. They might be able to steer you in the right direction. Your 18 so your probably not that mechanically inclined so if I were you I would take it to a offroad shop and try and get them to look at it and probably just have them fix it.
08 F-250, 6.4, King Ranch, captains, ccsb, 8 inch rough country, 37's on 22' monsters, volant intake, sct livewire innovative tunes, 5 inch turbo back flo pro, top gunz customs control arms, Iron bull
07 Mustang, GT/CS, LT's, Custom 3inch Straight Pipes, 20 inch Razors, Spector
11 F-450, 6.7
ajordan6337 is offline
post #9 of 9 Old 03-18-2013, 07:34 AM Thread Starter
Actually I am pretty mechanically inclined for my age. I've dropped axles, traction bars, pulled turbos etc. if it has a warranty then I'm golden. Thanks for the help
