Carli Replacement Radius Arm - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 74 Old 03-14-2013, 08:34 AM Thread Starter
OCVeloMan's Avatar
Quoted: 179 Post(s)
Garage
Thought I would throw a teaser out there since many have expressed interest. Sage has been working on designing a replacement radius arm for the Ford guys who hate the look of the factory arm. It will re-utilize the factory bushings in the axle and will connect at the frame end with a HUGE Johnny joint for better articulation and less binding of the frame-side bushing. As you can see from the below drawing, there is built in tire clearance as well.
For everyone running our 2.5" and 4.5" systems, these arms will be built to work in the stock mounting location for the 2.5" and will work in conjunction with our drop brackets on the 4.5" systems to maintain proper arm orientation. These arms will be the strongest thing around given they have internal gussets/bracing throughout the arms. We're shooting the drawing to our laser cutter shortly and should have a prototype within a month.
OCVeloMan is offline
post #2 of 74 Old 03-14-2013, 05:34 PM
shawnb99's Avatar
i remeber following these days when i had a dodge......
get ready boys, these will be the game changer for fords.....
$1800 rough guess ???????????
04 F-250 CCSB 4X4 6.0L Auto, tweaked by GEARHEAD
follow link to truck for sale
shawnb99 is offline
post #3 of 74 Old 03-14-2013, 09:40 PM
Hope the price is lower than $1800.00.
RH67 is offline
post #4 of 74 Old 03-14-2013, 10:04 PM
BIG Laing's Avatar
You know PMF and OUO already make these right? PMF's are about $900 and OUO are about $1200.
I hope Carli stays in the $1000 range. Errr i mean the $20 range.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #5 of 74 Old 03-14-2013, 10:42 PM
JesseKK's Avatar
Quoted: 62 Post(s)
Garage
Those look sweet. Now if i could just get me some King Coilovers
JesseKFK
2007 F250 XLT CC 6.0 PowerStroke FX4 R.I.P. 3.6.16
Livewire TS LOoNeY
Studded
BPD 58v FICM
BPD Oil&Egr Cooler
Glow Shift Pyro,Fuel
High Idle Mod UF#4
Fog Light Mod
Harpoon Mod
Dome Override Mod
6000k Bi-neon Hids
Sinister Coolant Filter
8in Rize Ind 4 link
35" Mickeys on 20s
Blue Leds
Power Service Every Fill Up
ATV 2008 Yamaha Raptor 700 FI
KCCO
Originally Posted by Karls03 View Post
I hate Edge power products so much, I quit using Edge shaving gel
JesseKK is offline
post #6 of 74 Old 03-15-2013, 04:23 AM
Fall Guy's Avatar
Quoted: 7 Post(s)
Looks like a nice setup, does Carli have any plans for 6" lifted heights in the future??
Fall Guy is offline
post #7 of 74 Old 03-15-2013, 05:03 AM
TripleE44's Avatar
Not the same thing man.
11 F250 6.7 CC/SB -- tuned & deleted -- 3.5'' PMF/ICON/Fox suspension, Method Standards, Toyo AT2s
TripleE44 is offline
post #8 of 74 Old 03-15-2013, 06:57 AM
I was thinking the same about $1000.00.
RH67 is offline
post #9 of 74 Old 03-15-2013, 04:13 PM
BIG Laing's Avatar
Explain? Unless your saying that PMF and OUO are adjustable 3-link radius arms, while this one looks to be a non adjustable radius arm.
post #10 of 74 Old 03-16-2013, 07:48 AM
shawnb99's Avatar
there are several "others " who make replacement arms.....
GAURANTEED that they are no where near as good as these..... the amount of R&D these will go through is unbelieveable.....
OCVELO......is there a truck currently that has been testing these? if so how long ?
typically by the time some one from the carli camp releases this info, there is at least 1 truck if not 2 alraedy beating the hell out of these.....
shawnb99 is offline
