steering stablizer neccessary for hydro ram assist? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-14-2013, 06:24 AM Thread Starter
should steering stabilizers be used when using ram assist? Always thought you didnt need them but alot of pics I see have people using them.
PowerstrokeAaron is offline
post #2 of 4 Old 03-14-2013, 06:30 AM
asian195's Avatar
Quoted: 2 Post(s)
Re: steering stablizer neccessary for hydro ram assist?
I'm not really sure, but it would seem that the ram itself would be sufficient enough...
2003 F-350 6.0L.
Leveling kit
35/12.50-20 Federal Couragia M/T
20x10 black Fuel Hostage wheels
4"-5" exhaust no cat
Airaid intake
SCT tuner-awaiting custom tune
Edge Insight CTS
Blue spring
6.4 Banjo bolts
Zoodad mod
EGR Delete
To Do/Wish list:
FICM tune
ARP Head Studs
BPD Oil Cooler/Filter
Fog light mod
Harpoon mod
Injectors 155cc
asian195 is offline
post #3 of 4 Old 03-14-2013, 08:17 AM
layson's Avatar
Quoted: 82 Post(s)
The ram is good enough. I have ran both types of setups. Either way works fine.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #4 of 4 Old 03-14-2013, 03:25 PM
banshee-rider's Avatar
Quoted: 7 Post(s)
Garage
a Stabilizer would be a waste the ram is alot stronger than any stabilizer set up.
2005 FORD F250 CREWCAB LARIAT
9 INCH LIFT
37x13.50x20 TOYO M/T'S
PMF TRACTION BLOCKS AND BARS
MBRP 4 INCH TURBO BACK
ARP'S,STAND PIPE'S, DUMMY PLUGS ALL THE UPDATES
SCT LIVEWIRE SRLxx
2008 SUPERDUTY TAILLIGHTS
OPT7 LED HEADLIGHTS AND FOG'S, 50 INCH LED BAR
AMP RESEARCH POWER STEP'S
AIR BAG'S TRAIN HORNS AND AIR COMPRESSOR
CUSTOM STEREO
XDP COOLANT FILTER
PSC HYDRAULIC ASSIST STEERING
RCD EGR DELETE
EXCURSION CENTER CONSOLE
2007 REAR VIEW MIRROR AND MIRROR SWITCH UPGRADE
banshee-rider is offline
