Solid axle swap - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-13-2013, 06:45 PM Thread Starter
Solid axle swap
Ok so i currently have a Dana 50 front axle in my 92 f250 4x4 5sp and I found a Dana 60 front and a new sterling for the rear (something is wrong with mine) for $400 which is cheaper than it would cost to have mine fixed so i figured i might aswell swap both front and rear axle at the same time. Any way the only problem is that all the grease fittings and stuff are shot and idk what all the different bars and arms are called in order to get the new parts and i have searched high and low for diagrams with no luck could someone please help?
thanks
1992 F250 Custom
7.3L IDI 5sp manual
Ford7.3IDI is offline
post #2 of 7 Old 03-14-2013, 08:07 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
It will bolt right up...make sure you get the drivers side U bolt plate..you cannot find them!
I'd also get the steering linkage, track bar and bracket, sway bar and brackets etc.
Now if you want to to ride geat when done we can set you up.
Cary
CT Performance, Inc. is offline
post #3 of 7 Old 03-14-2013, 08:34 AM Thread Starter
i have all of the linkage but the ball joint type things on the end are all shot and i dont know what they are called to get new ones, sorry for my ignorance im new to the world of suspension/steering
And what do you mean set me up?
1992 F250 Custom
7.3L IDI 5sp manual
post #4 of 7 Old 03-14-2013, 09:24 AM
Quoted: 3 Post(s)
We developed the RS kit SD spring mod in '99 and have helped hundreds get the best ride quality possible..we have everything plus 7 day a week support.
PM if I can get you info.
Cary
post #5 of 7 Old 03-14-2013, 12:08 PM
Sam Burton's Avatar
are you talking about the tie rods or the ball joints?
maybe a picture would help
1978 Ford Bronco
12v Cummins
ZF-5 NP 205 10.25 rear Dana 60 front
Denny T fuel pin 366 governor spring
HX 35 turbo BD exhaust brake
Powerstroke intercooler
1990 F-350 Crew-Cab Short Box XLT 4x4
Powerstroke E4OD
170cc stage 1 injectors, superduty intercooler, flowmaster 3" down pipe, 4" exhaust, 6637 filter, 17* HPOP, Wildman tunes, build E4OD, 5 disc billet converter, Irate E-fuel, 1.0 exhaust housing, WW2, CCV mod, homemade RSK
Sam Burton is offline
post #6 of 7 Old 03-14-2013, 12:10 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
the TTB dana-50 steerng linkage is different then the dana-60 linkage... make sure u grab it including the pitman arm!
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #7 of 7 Old 03-14-2013, 12:15 PM Thread Starter
Sam I'm talking about tie rods and I have all the linkage just need the tie rod ends but there are like 3 of them are they ask the same part or?
1992 F250 Custom
7.3L IDI 5sp manual
