Air bag overload line leak??????? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-12-2013, 05:55 PM Thread Starter
Smile Air bag overload line leak???????
I have firestone bags on the rear of my f-350 and the line is leaking. I asked an auto parts store about line and compression fittings no go there. Hardware store next door has line and fittings though. My question is what line and fittings should i be lookin for to repair this.
Thank you
Ozzy
ozzy1584 is offline
post #2 of 6 Old 03-12-2013, 06:03 PM
44magnum's Avatar
Quoted: 2 Post(s)
Usually when the line leaks it's because the ends weren't cut straight and clean. Use a tubing cutter, you can get that at the hardware store. Otherwise you need a 1/4 line iirc.
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
post #3 of 6 Old 03-12-2013, 06:53 PM Thread Starter
The line was ran ****ty by the looks of it and wore a hole in it what psi rating line should i be lookin for and what psi fittings.
ozzy1584 is offline
post #4 of 6 Old 03-12-2013, 07:03 PM
JesseKK's Avatar
Quoted: 76 Post(s)
Garage
AVS
Try this place if u cant find anything local
JesseKFK
2007 F250 XLT CC 6.0 PowerStroke FX4 R.I.P. 3.6.16
Livewire TS LOoNeY
Studded
BPD 58v FICM
BPD Oil&Egr Cooler
Glow Shift Pyro,Fuel
High Idle Mod UF#4
Fog Light Mod
Harpoon Mod
Dome Override Mod
6000k Bi-neon Hids
Sinister Coolant Filter
8in Rize Ind 4 link
35" Mickeys on 20s
Blue Leds
Power Service Every Fill Up
ATV 2008 Yamaha Raptor 700 FI
KCCO
Originally Posted by Karls03 View Post
I hate Edge power products so much, I quit using Edge shaving gel
JesseKK is offline
post #5 of 6 Old 03-12-2013, 07:42 PM
44magnum's Avatar
Quoted: 2 Post(s)
I would say 100 or 120 PSI. Everything online just says SAE and DOT rated.
44magnum is offline
post #6 of 6 Old 03-13-2013, 04:44 PM Thread Starter
Ok, than you all for the help i'll look in to everything suggested and see what i can find.
ozzy1584 is offline
