spring bushings - Ford Powerstroke Diesel Forum
Old 01-15-2008, 04:17 PM
spring bushings
How much are new spring bushing? Should i put them on before i put a used lift on ?
Old 01-15-2008, 04:29 PM
their not much. id def get them before installing that lift. maybe 30 bucks for the full set.
Old 01-15-2008, 04:30 PM
ok can i get them from any auto parts store
Old 01-15-2008, 05:37 PM
Im not sure. I get all my parts at the local 4x4 store. you can probly order them any where off the net.
Old 01-15-2008, 05:43 PM
I replaced mine with energy suspension poly bushing set. Took about 6 hours to do the work but was worth it. I could probably do it quicker the next time. Welcome to Energy Suspension!
Old 01-15-2008, 07:46 PM
I was going to suggest energy suspension bushings. those are the brand of cab bushings I got... if you replace em before you put the lift kit on it will only take you a minute or two per spring. wd40 works great to help pop them in.
Old 01-16-2008, 06:06 AM
what size of bushing will i need. Im gana try and order it so its here when the lift gets here
Old 01-16-2008, 06:16 AM
Energy suspension makes a kit. if you check there website you will find the part number for the kit. They also have a dealer locator on their website.
Old 01-16-2008, 06:33 AM
a shop told me i would have to drop my t-case down when i put the lift on for the right angle. Is this true
Old 01-16-2008, 05:20 PM
no. 6 inch isnt drastic enough of an angle to need to lower the transfer case. I had a half ton single cab short box with 8 inches of lift that I never had problems with and I never dropped the transfer case. I did have to have the drive line lengthened.
