97 f250 questions front axle - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-11-2013, 05:28 PM Thread Starter
okay guys im new to the forum but fortunately not new to the blue oval. I recently bought a 97 f250 that has an sas already done. I'm having some pretty bad hopping issues when running down the road. This truck is big i understand its not going to drive like a Cadillac. I also have one spring shackle that is broken. The previous owners were not the brightest of sorts i imagine and heres why. They tied the two front leaf spring shackles together with a crossover bar. Does anyone know of any rhyme or reason some one would have done this?? What im trying to calm down is the hopping and also to repair the leaf shackles and what im wanting to know is if these were at one time stock shackles and if i could find some new ones for it. I could pull these apart and do some fab work but just afraid they are too weak now seeing as one is cracked. I have attached several pictures and would appreciate any input on this as i would like to find the hangers pretty soon. so any links etc would be very helpful thank you in advance for your time. also im fairly positive that this is a ball joint d60 not positive so any insight into that would be helpful as well.
pbotexas is offline
post #2 of 6 Old 03-11-2013, 08:37 PM
Sam Burton's Avatar
i can't tell from the pics but did they add a shackle at the rear of the spring?
thats the only reason i could see for linking the front shackles and its a very bad way to do it anyway.
i would rip out everything they did and start from scratch. that is some hokey engineering.
1978 Ford Bronco
12v Cummins
ZF-5 NP 205 10.25 rear Dana 60 front
Denny T fuel pin 366 governor spring
HX 35 turbo BD exhaust brake
Powerstroke intercooler
1990 F-350 Crew-Cab Short Box XLT 4x4
Powerstroke E4OD
170cc stage 1 injectors, superduty intercooler, flowmaster 3" down pipe, 4" exhaust, 6637 filter, 17* HPOP, Wildman tunes, build E4OD, 5 disc billet converter, Irate E-fuel, 1.0 exhaust housing, WW2, CCV mod, homemade RSK
Sam Burton is offline
post #3 of 6 Old 03-12-2013, 05:17 AM Thread Starter
I would have to agree with you there and no shackle there I think im just guna stand her up that axle needs to be checked out anyways need new seals etc anyone know what the front leafspring mount supposed to look like.?
pbotexas is offline
post #4 of 6 Old 03-12-2013, 05:41 AM
DirtyDiesel's Avatar
Quoted: 4 Post(s)
undoubtedly, most of youre bouncing is coming from those tires, they are notorious for being a square tire. also i would find new shackles for sure, i just did a google search and found some, theyre a little pricey but IMO that isnt safe to be riding on.
Brett
'08 Ford F-350 Powerstroke Lariet 4x4
SPARTAN Tuner, Flo-Pro 5" Exhaust 6" Tip, Deleted, S&B Intake, B&W Hitch, 2.5" Leveling kit, Custom Rear Traction Bars, 20x12 FUEL NUTZ, 33x12.5 Toyo MT's, PIONEER Screen, 3500W of ORION amps, Sundown SD3 10" subs, Blacked out Headlights, Retro LED bulbs, Recon Mirror Lights
DirtyDiesel is offline
post #5 of 6 Old 03-12-2013, 10:00 AM Thread Starter
Yes those tires are rough. Thanks for your in put where did you find them?
pbotexas is offline
post #6 of 6 Old 03-12-2013, 10:25 AM
Quoted: 4 Post(s)
I just did a google search for Ford spring shackle. I think it was 1aauto.com had some.
Brett
