4" to 6"? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-09-2013, 06:15 PM Thread Starter
4" to 6"?
so im shopping around for lift kits right now and im stuck between 4 and 6 inch kits. i can get them for the same price so that cant exactly be a tie breaker. if i could find someone with the lifts i and take a look at them in person it would be easier, but no such luck. so my question is if i get a 4" lift and end up wanting more, is there like an add a leaf or blocks i can use to make up the next 2 inches? or would it be easier to get a 6" lift and knock it down a bit if that ends up bein too much?
Cduff is offline
post #2 of 8 Old 03-09-2013, 06:18 PM
BIG Laing's Avatar
What brand? It should be new shocks and coils to switch between the two.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 8 Old 03-09-2013, 07:30 PM Thread Starter
i have an 02 250 so its all leaf springs. im looking at the procomp kits right now. they seem to be one of the best deals. i know quite a few people who have procomp lifts and lovem
Cduff is offline
post #4 of 8 Old 03-09-2013, 08:40 PM
BIG Laing's Avatar
Oh, your 04 or older? I got sigs turned off, I assumed you had 05+,
post #5 of 8 Old 03-09-2013, 10:23 PM Thread Starter
i guess i should add one! i dont have a sig anyways!
Cduff is offline
post #6 of 8 Old 03-10-2013, 08:56 PM
I added 3 of 4 minipack leveling blocks under my 2.5 RC leveling kit to achieve a little over 4". You can add minipack blocks under a 4" to get 6" but it will ride terribly. I took mine off after about a month and did a shackle lift!
99Superduty78 is offline
post #7 of 8 Old 03-11-2013, 12:32 PM Thread Starter
where did you get your shackles?
2002 F250
Leveled on 35s
[SIGPIC][/SIGPIC]
Cduff is offline
post #8 of 8 Old 03-11-2013, 01:31 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
I would do a 4" front shackle lift and if u want to go higher add 2" lift springs. Add 5" lift springs in the rear and remove the 2" blocks which will give u 3" of lift in the rear. U want to go higher, put the blocks back in. But ultimately stay away from that pro comp lift and do it right the first time.
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
