Replacing Ball joints and tie rod ends
Iam in need of new passenger side upper and lower ball joints and all outer tie rod ends I am thinking about doing all moog problem solver greasable parts. Rock auto seems to be the cheapest on the Moog parts what brands are you guys all running?
I used Moog Problem Solver upers and lowers on my 2003, I couldn't see trusting my 6 year investment to some Circle K $35 ball joints.
As long as you're in there, may as well do both sides and get it over with, I did. |
Yeah I already did the drivers side with Moogs upper and lower, But I am wondering what other options that are out there or opinions.
In that case, I would DEFINITELY use the same Moog on the other side.
Cool thanks for the input man!
never checked rock auto but check amazon.com almost half the price oreilly wanted
Re: Replacing Ball joints and tie rod ends
Rock auto has some that are far less than what I paid, too, but I'm not trusting my truck to $15 ball joints. I can be hard on my truck and that's when you seperate the good parts from the garbage. Definitely don't want to launch your Souper Doody on cheap parts.
I don't try to, but it happens none the less. Sent from my LG-VS700 using AutoGuide.Com Free App |
Look into XFR ball joints, or even the greasable motorcraft joints.... If u stay with MOOG go to partsgeek.com. prices are slightly lower then rockauto and shipping is far less.
http://www.partsgeek.com/catalog/200...all_joint.html Last edited by ol_Blue97; 03-11-2013 at 11:21 AM. |
Last year, I had to replace the upper and lower on the drivers side again..so instead of wondering when the other two would fail, I replaced them with Moog. If these fail anytime soon, I will drop the cash for the dynatracs. Hate doing the same job every year or two. Not saying the XRF are junk, just that my experience was less than stellar. |
Thats good to know..... Those dynatrc joints are awesome but $$$$, in your case doint the job twice and having to replace seals every time u do it, u would have broke even most likely.
Ive never had a problem with MOOG joints in the past but it does seem their product is changing. More and more i think about it, i may just stick with motorcraft as i know they usually last 80-100k and that all i will put on ball joints regardless if they are still goof or not.... well except the dynatracs. |
