New Shocks to Level/Lift Truck - Ford Powerstroke Diesel Forum
Old 03-03-2013, 11:07 AM
I'm kinda new to this sort of thing. I have a 2001 F250 7.3 4x4 and I'm looking to level out or add just a slight 2" lift to my truck. I also am interested in replacing all my shocks to Bilstein or another high quality after market shock. Is there any kits that do this? I have seen many different ways to lift/level a truck and I'm confused on what route to take. Any feedback would be appreciated! Just looking for a little bit more aggressive on my new power wagon.
Old 03-03-2013, 04:38 PM
here are three people who can acheive this for you very easily
no specific order ....
8 lug truck gear ( george )
Precision Metal Fab ( trevor )
CT Perfomance ( cary )
all trhee now the stuff in suspensions,
you can go a couple of routes,
1. under the spring MINI PAK, thie will lift, but retain axle to frame distance for stock shock applications.
2. shackle / hanger kit, this lowers the mounting placement of the factory springs, ths warrants same ride as stock, but shocks will need to be longer
3. replacement leafs, either X code factory (plow package springs ), or aftermarket.
any way you choose, these guys can set you up with all that is needed.
Old 03-03-2013, 05:25 PM
Is there any drawbacks to doing a hanger/shackle kit? I've seen a few with some shock replacements that I was interested in. I still think I prefer a shackle kit with Bilstein 5100 shocks. Is that a good idea?
Old 03-04-2013, 05:29 PM
i would say yes, it should net the best ride, IF you currently like the ride of the stock springs....
the 5100 is a little stiff for some, but i like them. nice handling and feel, but not harsh. and way better than ANY white body shock.
Old 03-05-2013, 06:06 AM
Feedback Score: 5 reviews
Best ride quality is always from a Hanger kit as it retains the factory spring and allows more suspension travel. You will need longer shocks and a adj track bar.
we have all, PM if I can help.
Cary
Old 03-14-2013, 06:58 AM
Cary
Cary, im looking for the same setup as this guy....can you shoot me a PM on with a quote please with Bilstien 5100's. All I have now is stock suspension and STOCK shocks with 33" Mud Terrains.
Old 03-14-2013, 07:37 AM
Are you just wanting shocks or a complete hanger kit? size tires you want to run?
If Send me a PM with year and what you want....and the installed length measurement bolt to bolt of the shocks with the truck on the ground if just shocks, I like to insure correct fitment.
Old 04-01-2013, 08:01 PM
Hey, not sure if you ordered anything already but... I just put on Pro Comp 22210 2" level springs, Zone adjustable track bar, and Bilstein 5100 shocks. I couldn't be happier. The ride is firm and controlled without being jarring at all. I gained noticeable travel and flex, too. Mine is a 2000 7.3 F350 so pretty much the same as yours but mine is 1" taller in back. The small extra cost is worth it in my opinion. To answer your question (instead of trying to sell you stuff) Yes, there are drawbacks to a hanger shackle kit. It rotates your axle backward slightly which changes the angle that your front drive shaft comes into your front differential (probably not a big deal). You will have "hangers" hanging down noticeably behind your wheels (not a big deal). You will still have your old, stock leaf springs (a big deal to me). If your front leaf springs are less than an inch from the bump stops then they are sagging. I would say that instead of spending money patching up the old stuff, you could spend a bit more and get brand new stuff.
