I have an 03 f250 6.0 4x4, and i dont know what size lift is on the truck. i do know that my buddy has a 6 inch lift on his f150 and we are the same height. i need help on tire size i want to put some 20x12 with a -44 offset and i want to know if i will be able to fit 35s or should i stick with 33s and i also read that if you go with to big an offset you can mess up your vehicle any info would really help.
4" farther out then stock is pretty far out there. Even with a 6" lift I think 35's would rub. I am guessing you have a 3-4" lift? So I would be surprised if 33's clear. Why do you want 12" wide wheels? What tire width are you wanting to run? |
And yes the farther your wheels are sticking out, the more stress you are putting on your steering/suspension components. So wheel bearings/ hubs are going to wear out fastest, then everything else like power steering pump, tie rods, ect...
well i want the wide wheels because i like the deep dish look, if its really gonna wear things alot faster and be hard on the truck i may not do it. but i was going to run a 35x12.50x20 tire or same thing just 33s.
You would be much better off with a 10" wide rim. |
