Pitman arm nut
Does anyone know what size nut is on the steering box holding the pitman arm on?
What year truck?
I think it is crescent wrench size
LOL ya what year ? |
My bad it's a 05 F250!
Hmm
give me a few My 06 is out front next to a set of metric sockets |
Lol, its supposed to be tightened to 350-400 ft lbs, so Im guessing a crescent wrench aint doin $hit!. Should be 46mm. Kinda crosses over to a 1 13/16".
well chit I have a drop bracket that is keeping me from slapping a socket on it
and it's bigger that any of them anyways let Me see if My OEM manual has it specked |
Thanks Trev
I know the track bar was 400 ish but the pitman arm also ? wow another issue is trashing the box when it's sitting against the stops and doing the torque some kits come with a tightening fixture to avoid that issue |
Ok next thing I have a 6" lift with 37's and I have the problem with the pitman arm coming lose and making the steering very sloppy. What to do to fix this problem?
thats not good the sector shaft taper may be fubared or the Arm itself
but also getting to the 350-400 lbs spec isn't easy so you might not be getting it |
