Should I be able to move track bar? 2012 F250 - Ford Powerstroke Diesel Forum
Old 02-23-2013, 11:44 AM
I have a Carli track bar that I can move back and forth by hand. The part that moves is the ball joint.
I am trying to find a squeak in my front end.
Old 02-24-2013, 10:54 AM
with having heim ends, you will be able to give it a light twist, but not any movement in the ends.....if the joints seem to wiggle, try tightening them.
Old 02-25-2013, 07:47 AM
Feedback Score: 5 reviews
They can also start to squeak you can't tighten the joint itself...the inner ball will have rotational movement.
IMO and the majority of others will say Heim joints are for off-road use only.
Old 02-25-2013, 10:11 AM
is it a heim joint? It probably needs to be replaced. I am with Cary on this one...
Old 02-25-2013, 12:59 PM
Since both ends can pivot I assume that you are talking about twisting the bar and not actually moving it left and right. That is totally normal.
Old 02-25-2013, 01:23 PM
Agree with George. If you get a pop or the ball joint have vertical play, it may be time for a new ball joint.
I am about to post a video of what I am talking about.
