2008 F250 - 4" BDS question
Can I use 1" spacers under the coils to acheive 5" of lift?
I have read some member's lifts described as ____ lift with 1" TEI spacer - is this what that means - using the 1" under coil spacer?? |
Seems like it might be a bit unstable to add a spacer to a lift.
![]() If anything, here is a free bump for ya! |
You can but since the BDS Kit doesn't have Adjustable Caster, you may need a different Caster adjuster for the upper ball joint.
Anyone know what their caster is with the 4" kit, the 6" kit, and what size the cams are with the 6" kits? |
yes you can, and I would order the caster cams as well if you add the 1" spacer. If you dont do caster cams then look at a 4 link or a 3 link to adjust caster.
I am curious as to the contents of the 'box kit' portion of the lift (sway bar end link extensions, radius arm drop brackets, longer pitman arm, etc) for the 4" vs 6". Curious if they are different lengths? If I go 5", wonder which would be the better way to go?
Can anyone comment on the BDS rear spring kit - ride, trailering 'sag', etc? I see the 4" and 6" kits use the same spring, just the 6" uses a 2" longer u bolt than the 4" kit - wondering if they use a 2" block on the 6" kit?? |
