Leaf spring ID help - Ford Powerstroke Diesel Forum
Old 02-09-2013, 08:47 PM
Leaf spring ID help
So I am am looking doing a front and rear springs for a v/b code upgrade on my 2005 Excursion.
I have been able to get some almost brand new v-codes for the fronts and have come across rear springs but don't know what their spring code is from the numbers.
I know we could look at the label on the donor truck but that is no longer available.
They are from a 2004 F250
Here is a pic - I am hoping someone had the same numbers to help verify the spring code.
I know its almost an impossible task but hoping to get lucky and someone has the same numbers to verify.
Old 02-10-2013, 07:57 AM
Feedback Score: 5 reviews
#'s usually won't help..those are not part #'s..but those springs look correct.
If we can help let us know.
Cary
Old 02-10-2013, 08:29 AM
Cary
So they like B codes with the auxilary spring on top. Correct?
If I remove the auxilary spring and block, you will have standard B code rear springs. Correct?
Any what to tell if they are B codes by measuring?
The see the possibilities are ??
1. A-code springs
2. B-code springs
3. C-code springs
4. ?-code springs
Questions...
1. Did A-code springs from an F250 in 2004 come with the top overload leaf that is in the picture?
2. Did an F250 in 2004 come with a C-code spring?
I just want to make sure that I get B codes for the rear of my Excursion and any help would be appreciated. As you can imagine I do not what to buy something that I can't use.
GoldenGun
