- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
front vs rear springs size
i recently lifted my truck and it is bulldoging by about 2-3 inches. it has 6" springs up front and a 6" block in rear. turns out i should have put a 2" under that i guess. my question is would it be possible to use rear spring to replace the 6" fronts? my buddy has a set of 5" rears that i figure if they fit should compress a little more and end up with about 3.5-4" from the weight of the engine. i like how the back sits being about 4" above stock with the 35" tires. will the rear springs work on the front, or what is the cheapest option to lower the front to match the back?
| Sponsored Links |
it is a fabtech 6". it came with 4 inch blocks and since mine came with a 4" from the factory i thought well 2+4=6 so i just put a 2" in. but i like the height the back is at, just need to lower the front down a few inches. i was really hoping that those springs would work, whats different about them? length? load?
why not just lift the back a bit? it would be cheaper by either adding some full springs or just an add a leaf... add a leaf is the cheapest way to go... but already having a 6" block (or 2 in your case) makes the truck ride like crap.... go with a full spring replacement to raise the rear or just do a simple add a leaf that will lift it 2".... but if you really want to lower the front you will need to go with 4" springs just to make the front a lil lower... which is gonna be more expensive -Raul |
yah i can get you 4" springs... first i need to know what year truck you got... also since your kit is for a 6" lift you will need smaller shocks for the front if you keep the stockers and hit a big bump you will bottom out the shocks since they are gonna be to long.... what brand leafs do you want? the cheapest or some fabtech ones to match your kit?
k bud ill pm you a price... but first i need to know if you have an early 99 or older 99 model?
| Sponsored Links |
