leveling kit steering wheel issues
i recently added a 2.5 leveling kit with radious arm drops,track bar bracket spacers,shock & bumpstop extensions. this left the steering wheel at a 12-6 o'clock position. took the rig to get aligned at firestone and now the steering wheel has a 8-2 o'clock position. they also told me i needed a new right side outer tie rod which i had them replaced due to it being loose/etc. gonna bring it back tommorow to see if the can fix it. what could it be?
![]() also i hear a faint "clunk" noise whenever i accelerate past 1st gear, this was before the level kit . |
It a very simple procedure to straighten out your wheel, u can do in your driveway in about 5 mins!! I dont know the tecnical term, but the union on the drag link by your pass tire, loosen the 13 mm bolts and use a pipe wrench to rotate the union piece. Turn one full turn and your wheel should be close. You will have turnthe union a little to see which way it turns the steering wheel. Make sure your steering is unlocked, keys in ignition. This does not affect alignment, it only centers the steering wheel.
Gb |
