Steering stabilizer help - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-03-2013, 01:33 PM Thread Starter
Retired Army
Quoted: 2 Post(s)
Bought the truck a week ago and it doesn't have steering stabilizers although the front tie rod had a Fabtech mount with the two outboard mounts for a dual-stabilizer setup. Wondering which stabilizers will fit? The mounting nuts are also missing although I can probably go to Ace and find the size / pitch, and washers too.
I'm also experiencing tire rubbing when at almost full lock, worse at right lock than left.
Driver-side leaf:
Passenger-side leaf:
Ideas? Thanks.
Richard
2004 F250 SRW FX4 Lariat CC LB
Sinister delete, XDP coolant filter, NUC oil bypass, fumoto valves, AFE stock replacement, Riffraff boots, Ultra ELC, CTS and Glowshift gauges, SRL, Wicked Wheel
08 trans pan/filter, 08 diff cover, Racor CCV6000
ranger51r is offline
post #2 of 6 Old 02-03-2013, 03:10 PM
HarvestingInternationally's Avatar
for the rubbing i believe u can use spacers
http://img716.imageshack.us/img716/2580/oppt.jpg
2006
F250 Crew Cab Long Bed 6.0 TurboDiesel FX4
Diesel Site Coolant Filter, Edge Insight CTS, BPD FICM 48v, Metal CAC Tube, Blue Spring,Sinister Diesel EGR Delete w/ Up Pipe, Riff Raff Boots, MBRP 6212-409 Exhaust, BFG AT's,
Bilstein 5100's with Leveling Kit, ISSPRO EV2 Gauges (Pryo
, Fuel Pressure)
Eric
HarvestingInternationally is offline
post #3 of 6 Old 02-03-2013, 04:05 PM
LEARNING AS I GO
bck4more's Avatar
YEP THATS WHAT I HAD TO USE
1999 Ford F-250 Crew Cab Lariat 4x4 7.3L Powerstroke zf 6-speed Planet colors Amber White Pearl
banks big head wastegate, edge ez module
snow performance, 4" stright pipe,6637 FILTER MOD southbend stage 2 clutch, 05' front end upgrade
8" procomp 37" M16 Swampers 18x9 xd monsters, MOOG everything BILSTEIN SHOCKS BILSTEIN DUAL STEERING STABILIZER COOLANT FILTRATION, 203 stat 08' mirrors
bck4more is offline
post #4 of 6 Old 02-03-2013, 04:09 PM Thread Starter
Retired Army
Quoted: 2 Post(s)
Where do the spacers go, between the wheel and the hub? If so, I thought those were a bad idea, although I cannot remember where I heard that.
post #5 of 6 Old 02-03-2013, 04:10 PM
yes..too much is no good..i doubt u need that much to get rid of the rubbing
2006
, Fuel Pressure)
Eric
post #6 of 6 Old 02-03-2013, 04:54 PM Thread Starter
Retired Army
Quoted: 2 Post(s)
So something like these?
Although maybe not that thick.
