Steering Wheel Play - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-02-2013, 06:34 AM Thread Starter
Steering Wheel Play
Okay so here is my problem when i turn my steering wheel there is like 25 degrees of play or so which doesnt really bother me too much but now sometimes when im turning at low speeds it feels like i lost power steering and the wheel also moves up and down? any help would be greatly appreciated.
Ford7.3IDI is offline
post #2 of 8 Old 02-02-2013, 07:41 AM
merc123's Avatar
Power steering pump and box failure maybe. My steering had a lot of play and before I got it fixed the pump started to go and wound up almost losing brakes.
'00 F350
Mods: Nitto Trail Grapplers, Diamo 17 Karat wheels, Red-head Steering box, Autometer gauges, Tru-Cool #4739 trans cooler, BFxenon HID lights
'03 Mustang GT
Mods: A bunch. -->
merc123 is offline
post #3 of 8 Old 02-02-2013, 07:46 AM Thread Starter
i guess i better get on that then
post #4 of 8 Old 02-02-2013, 10:11 AM
06Lariat_'s Avatar
Yeah could be the pump or the steering column
06Lariat_ is offline
post #5 of 8 Old 02-02-2013, 10:27 AM
JJFLASH's Avatar
Quoted: 111 Post(s)
Your column sits in bearings that keep everything nice and straight. When they start to go you will get movement in your column. When they get bad you will get binding, poor steering, wandering on the highway, serious play in the column/wheel. Simple to replace (relatively) and Ford sells complete rebuild kit for pretty cheap.
Odds are your steering box is loose after 20+ years of driving. Will be a big set screw with a jamb nut on it on the steering box. Bugger to work on but soak it with penetrating fluid, crack the jamb nut and turn the set screw in tight then back it off about 3/4 of turn.
Inspect your pitman arm, drag link, tie rod and ends. Should be tight with zero play in them.
Pump likely has nothing to do with it.
-JJ-
Mine - 94.5 F250 ZF5: Basics w/a few extras, DIY bumper, steps and exhaust, AFEII, D60, PMF 2.25 RSK, V-codes
Hers - 04 GM 2500 CCSB 4x4: LB7, EFI Live by KW, 2" Lift, MBRP 4" dp back
RIP 15/08/23- 98 GM 1500 ECSB 4x4: 6.5, straight pipe, K+N filter, 495km w/original pump, trans & t-case
JJFLASH is offline
post #6 of 8 Old 02-06-2013, 07:17 AM Thread Starter
okay so i replaced the pump on account of me having one on a parts truck and that wasnt it so im just going to try to tighten up the steering box and hope that gets me somewhere
1992 F250 Custom
7.3L IDI 5sp manual
post #7 of 8 Old 02-06-2013, 11:36 AM
merc123's Avatar
I tightened my box the first time as well and after a few weeks the play was right back. The issue with using the set screw is if you do too much it can strip the box and when you go to steer it won't steer. Makes for an interesting time when going through winding roads.
I noticed that when my steering box was going out it was near impossible for me to turn my wheels when the truck was sitting still. I had to let the truck roll for the wheels to turn. When I replaced the entire box it pretty much fixed this issue. Occasionally it won't turn at idle if the tires have a lot of traction but most of the time it is not an issue.
I replaced mine with a Red Head steering box. It was a little pricier than most but reviews on them from folks said it was a top notch. Also, you can send them your core back in a flat rate box for $15. Not bad for such a heavy piece of equipment.
'00 F350
'03 Mustang GT
Mods: A bunch. -->
merc123 is offline
post #8 of 8 Old 02-09-2013, 07:35 AM
Having the same issue. Can't help you, but also need some advice. Changed my power steering fluid, and it didn't help. Could it be the hardware components under the front? What about the belt? I guess if the belt is bad it can hurt steering. The power steering unit could go bad as well. All these possibilities and I am not a mechanic. If anybody can help please give advice! BTW, I have an '08 6.4 F350, DPF off. No lift kit, everything else standard except for my mounted .240B on the hood :-)
lewisduk is offline
