Level kit - Ford Powerstroke Diesel Forum
Old 01-28-2013, 02:08 PM
Level kit
I want to get the fron of my 05 f250 up and get some bigger tires under it, I want to do a 2.5 inch level kit but i dont want to do the coil spring block kit. Id rather just get new coil springs as my truck already has 185,000 miles on it, Ive came across these 2005-2013 Ford Pickup F250, F350 Super Duty 4wd - 2 1/2 Front Leveling Coil Kit Super Duty 4x4 Standard Ride - TTC-2813 | $163.95 and wanted to see what you guys thought or have any other ideas. Not looking to spend more then $300 on a kit, also what size tires can i fit under it with a 2.5 inch level kit on stock 17in rims thanks!!
Old 01-31-2013, 09:41 AM
While there is nothing wrong with the kit you posted, they are still using linear rate springs. With a linear rate spring, the longer it gets the stiffer the ride quality is going to be. Another thing is they do not include the alignment eccentrics neccessary to get your caster back in spec after the spring kit is installed.
Our spring kits are progressive rate, ride better than stock, and come with the eccentrics needed to aquire a proper alignment.
2.5" 2011+ Ford SuperDuty F250/F350 Diesel Lift Coil Springs
We have them in stock and ready to ship for all models 05-13. Being a forum member nets you a 5% discount
Thanks,
Derek
Old 01-31-2013, 11:41 AM
How do i go about getting my forum discount then and how big of tire can i fit i was thinking about going 315/70/r17s
Old 02-04-2013, 07:10 AM
To get the forum discount, you would simply give us a call and place the order over the phone.
You may be able to fit that tire if you retain the stock wheels, but if you are going aftermarket I would reccomend a 305/70 due to the increase in width and turning radius of aftermarket wheels.
Derek
Old 02-04-2013, 08:37 AM
Feedback Score: 5 reviews
You must use a adj track bar...so your budjet won't fly....
Unless you get shock extensions..you need new shocks.
F250..with 2.5" coils lilely will need taller blocks.
