Go Back   Ford Powerstroke Diesel Forum > General Topics > Suspension & Steering
Old 11-23-2007, 06:16 PM
RRRDAD RRRDAD is offline
Front end popping noise
When I initially put the truck in drive and make a turn the front end will make a popping noise. This is a 95 f250 4WD. At one time I was told this was due to the huck rivot. Drill it out and weld it or bolt it. No idea where or what this is. Any ideas on what would cause this noise ?
Old 11-23-2007, 06:23 PM
460+ 460+ is offline
Dose it have auto locking hubs? If it does you may have one ingaged.The huck rivot I
think they are talking about is the crossmember under the engine on driver side that conects the cross member to frame rail.
Old 11-23-2007, 06:31 PM
it has lock outs
Old 11-23-2007, 06:59 PM
You might check ujoints and all front end parts - ball joints and steering linkage- make
sure its all tight.
