- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
Suspension Question
Go ahead and thread merge if this has been discussed time and time again.....just couldn't find where it is.
I have a 2006 F350 Turbo Diesel crew cab automatic trans fully loaded. The truck at 38,000 miles sounds like a rusty hinge on a barn whenever I drop over a curb or the body twists significantly. I already know that nearly all the joints in the suspension do NOT have grease fittings which I do not appreciate ford trying to keep job security top notch on the second level. I however was wondering if you all have ever taken hyperdermic needles or anything into the rubber boots of these moving joints and squirted grease into them. I haven't gotten under this truck since I bought it, I know those joints cannot be greased but I was shown that trick on my 97 years ago that saved me a bundle from putting it into the garage, which involved a needle injection into the boot of the control arm linkage. Worked like a beauty and even though I had to do it every 6 months, I knew it was getting lubricated. The bottom line in all this is I'm trading this truck in next year for a bigger newer truck I'm ordering from ford. Anytime you can remove friction it will last longer and I will NOT replace suspension parts on this truck before I unload it for a new one. If I was planning on keeping this truck for a longer period of time I would not follow this crooked path......just want to limit wear on those joints, keepem quiet and get this truck to trade-in capability. I bought a short bed truck and never again....looks odd with a cap on it and defeats the truck. |
| Sponsored Links |
Was this a taboo question on this site?
I know for sure that others have this problem; no grease fittings on the OEM parts on these fords. I'm nearing 40 thousand miles now and this truck sounds literally horrible now with all the squeaking/creaking going down the road hitting bumps. It's so loud that I'm hearing it over the diesel motor at 55 mph which is insane. Are there any pivot points I can somehow get lubrication on or rubber joint sockets I can drill and put grease in till I trade up? |
Have you tried just hitting some of the dry spots with WD-40 and see if the noise goes away so you can get a better grip of where its coming from?
You just might have a issue with a warn bushing that needs to be replaced? Sorry wish I could see it to better help. Nor-Cal Nick |
| Sponsored Links |
