Urgent! Carli Full Rear Leafs; Please Help - Ford Powerstroke Diesel Forum
Old 01-13-2013, 12:07 PM
Hey guys,
I'm in the process of installing a Carli Pintop 4.5" kit with full rear leafs on my 2012 F250. Unfortunately, it seems that I didn't receive any instructions for the rear suspension installation. At the moment I'm in a bit of a bind because I need to have the truck back together and running by tomorrow morning, and being a Sunday afternoon Carli and all of their dealers are closed. Can anyone here on the forum post a picture of how the full rear leafs are installed?? On the 2011+ F250's (from the factory) the U-bolts face nut down and there is a bracket on top of the leaf springs and below the axle. In the case of the Carli full leafs, it does not appear the the bracket on the top of the leaf spring (between the U of the Bolt and the upper face of the leaf) can be reused. Does the U of the U-bolts just sit directly on the leaf spring?
Thanks in advance,
Craig
Old 01-13-2013, 02:19 PM
Sorry I can't help much, hopefully someone can shed some light. But I would say try putting it back together as it is stock.
Old 01-13-2013, 09:26 PM
Originally Posted by 12KR View Post
Hey guys,
Thanks in advance,
Craig
Use the top bracket, the new U bolts also face down. The center hole on the bracket needs to be drilled a little bigger to fit the Deaver centering pin and nut.
Old 01-14-2013, 04:29 PM
hopefully, you got it figured out.
by chance, where are you located, i am looking to purchase a set of 08-up rear leafs.
Old 01-14-2013, 04:46 PM
I have a set with only 500 mi. but i`m in SoCal.
Old 01-15-2013, 07:36 AM
Did you get the copy of the instructions that I sent yesterday?
Old 01-16-2013, 02:17 PM
Seems I'm a bit late to the party but this may help future people who find this thread:
http://forums.carlisuspension.com/file?id=1458519
Old 01-16-2013, 02:59 PM
The new instructions are better and with more detail, good deal.
Old 01-16-2013, 03:49 PM
Just finished them up yesterday. Have all instructions done for all ford systems and components!
