Go Back   Ford Powerstroke Diesel Forum > General Topics > Suspension & Steering
Old 11-10-2007, 05:33 PM
rbond rbond is offline
Question Popping Sound from rear when backing up
I am looking at purchasing a 1999 7.3 diesel F350 Dually with 50,000 miles. It has a popping sound in the rear wheels when backing up and the steering wheel is turned. Is that the rear end? If so, does it need replacing?--
Old 11-10-2007, 06:33 PM
twildman twildman is offline
Sounds like the limited slip differential is popping
Old 11-10-2007, 06:54 PM
460+ 460+ is offline
Same here, sounds like the clutches are binding up.Has the diff been worked on recently?
Old 11-10-2007, 09:25 PM
StarDriver StarDriver is offline
Add some Friction Modifer to the rearend, I'm guessing rear lube was changed and it didn't have any added to it. My Dodge and a 2001 PSD did the same thing when synthetic was put in them.
Old 11-13-2007, 04:58 PM
HellBilly HellBilly is offline
When u-joints start to go out thay start to "Click" when your in reverse.
Old 11-14-2007, 08:33 AM
pf350 pf350 is offline
full lockers will also do this. wouldn't that be a nice suprise to find you had a $600 detroit in there.
