- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
Confused about leveling
Read alot on here about leveling to get a larger tire to fit, which I am interested in doing, along with new rims. Problem is this, my rig, 2003 F250 FX4, looks level to me, but I have investigated some leveling kits from different mfg's and store websites. Here's my ?, I don't see a kit for any 2003 trucks, do they not need it, did Ford decide to do its rearend hike after that year? Am I overlooking the my year? Any answers are appreciated.
| Sponsored Links |
They do make leveling kits for your rig, but you may want to take it to a tire and suspension shop to confirm that it either does or doesn't already have one. If you do decide to purchase a kit then I believe that you'll need to put a larger block (F 350) in the rear since it will make you front end a bit higher. There are several options that you can do to level your truck. One is a spring hanger kit, 2nd is a mini spring pack, and last is an add a leaf. I chose option 2 but haven't installed yet. It is in my garage if you would like to see what it looks like. It's made by Tuff Country, but DR also makes one similar to it. Hope this helps a little, Moon |
here is a leveling kit for you. this is what I will be "lowering" to once my m/t's wear out. Donahoe Racing: Ford Super Duty 2" Mini Spring Pack
I have the same truck and have 145k on it. If its looks level right now then something must have already been done to it b/c every 2003 i've seen has had a noticable grade. I just leveled my truck last weekend and I used the Pro Comp leaf springs kit. People have told me that the leafs might wear out in a year but I chose that kit bc it came with shocks for all around. I couldn't be happier with it right now. the front sits 1/2 in lower and my ride is actually a whole lot better.
Sloth, you wont need to replace the track bar with a new one if it is 1" in diameter. Some rigs have 3/4" track bar that will need to be replaced. To check, see if you can slide a 3/4" open ended wrench over the bar. If you can then it should be replaced if you are using the Tuff Country leveling kit.
Moon |
| Sponsored Links |
