New or Used Posi for Rear?? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-04-2013, 11:28 AM Thread Starter
drkhrse's Avatar
Hi Guys, My truck came pretty option free for a 2006 XLT. I'm tired of the one legger rear end and want to install a Posi. My question is, is it better to buy a factory used one from a salvaged truck OR buy a new Posi-trac unit? If a new posi what ones are worth it for the money? I have no plans to change the gearing.
2006 F250 SD - Lift w/35's, aFe Exaust, Edge Chip
drkhrse is offline
post #2 of 6 Old 01-06-2013, 09:09 AM
Metal Mulisha's Avatar
I wouldnt put a stock limited slip in. Mine does one wheel peels alot. It seems to work offroad and on ice and snow though.
2006 F-250 Lariat
Super Cab short bed
20% tint
20" LED light bar
Diamond eye 5" straight pipe
River City Diesel EGR delete
ARP head studs w/ OEM gaskets
Blue spring
SCT X3 xtreme street
Edge Insight CTS
Mag Hytec diff cover
7 inch Icon lift
20x10 machinedFuel Hostage rims
37x13.50x20 Toyo Open Country M/T
Metal Mulisha is offline
post #3 of 6 Old 01-06-2013, 09:46 AM
Don't you worry about it
strokinpower's Avatar
Quoted: 270 Post(s)
I would also not spend any money on a stock unit. Look at the TrueTracs
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #4 of 6 Old 01-06-2013, 10:24 AM
My TrueTrac kinda does the same, one wheel peels when you are turning right, favors unloaded wheel (even tried a few e-brake clicks before going up RTI ramp). Your stock LSD has the option of having the clutches replaced, my TrueTrac has been this way since day one.
If you're not paying too much for the OEM unit, I would buy a set of clutches for it while it's out, they aren't hard to change/set up. Otherwise, Detroit Locker or nothing is what I have learned the hard way.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #5 of 6 Old 01-06-2013, 10:31 AM Thread Starter
drkhrse's Avatar
I have a Detroit locker in my '69 stang, I would not expect it to be a good truck diff. If I buy a used stock limited I will put new clutch packs in it.
drkhrse is offline
post #6 of 6 Old 01-06-2013, 10:42 AM
The short wheelbase, narrow track width, and the light weight of your '69 Mustang is why your Detroit Locker seems so aggressive. I have a Detroit Locker in a 4.56 geared 14 bolt with 38s under my mud truck and you can't tell it's there. Yes, it has been street driven in that configuration.
I know where you're coming from though, I had a Lock Right in my '67 Mustang (I mini-spooled it for the full aggression effect).
Karls03 is offline
