Leveling Kit - Ford Powerstroke Diesel Forum
Old 12-16-2012, 10:38 PM
Leveling Kit
Ive got an 07 Ford F-350 DRW and im looking to level the front of the truck to the back height, i bought a 2.5" leveling kit would that make me taller then the back? If yes then what would make it level... what size?
Old 12-16-2012, 11:32 PM
I put the ICON kit on the front of my 06 F250 CCSB. It made me 1" taller to the front. Swapped out the F250 rear blocks with F350 blocks and I am level, or at least close enough that it looks right. Hope that helps.
Old 12-17-2012, 04:30 PM
How bright are your PIAA head lights? Are they blue color or bright white?
Old 12-17-2012, 04:58 PM
Bright white. I had a lot of plans for this truck when I first joined, sadly I haven't had the time to do anything with it really. but the set in the grill are the white ones, they work, but for the price idk...
Old 12-17-2012, 06:22 PM
are both are ya'll trucks non 4x4s if so what front leveling kits yall use?
Old 12-19-2012, 07:40 AM
Feedback Score: 5 reviews
Have you measured to see what height you need?
Best ride quality will always be from using a V code factory spring. You can get a hanger lift in 2,3 and 4.5" which will enhance the ride quality by giving additional travel.
If you want new springs and 2" and the best ride quality get X code springs will ride better than any lift spring.
As always a 2" lift needs longer shocks and requires a adj track bar or a correctly made drop bracket to correct the axle that has now shifted 1/2-3/4" per 2" of lift. Its geometry.. a science. The axle shifting will side load your spring bushings which will cause premature failure and doglegging.
PM me if I can help.
