What size lift do I have? Pics inside
I bought the truck used. It has 355/60/20 nitto terra grapplers right now with no rubbing or trimming. Here are a couple pics of the rear block. Not sure if only the block determines the lift or all the components added together.
Thanks Sent from my SGH-T889 using AutoGuide.Com Free App |
Truck is in my sig but its a 2007. Just stated tires size so you would be able to guage my lift in reference to the tires but forgot to add the pic so here it is. You must be on your phone and not be able to see the pic and info in my signature
Wish I could help with your question. Just wanna say damn nice truck dude!
Sent from my iPhone using AutoGuide.com App |
Thank you
you have a stock f250 block, on top. and a 5" lift block under that..... somewhat of a dangerous setup, with the torque these trucks make, they are known for spitting stacked blocks out from under the truck. look into a block that is the height you need, and incorporates a traction bar mount. then add traction bars.
Looks like a 6 inch lift to me.
So being a 5 inch lift block is it a 5 in lift or 8im lift. I will surleu look into a single block
Sorry to derail, but isn't there a compilation of factory lengths from axle tube to frame? That would really be the only way to tell. Everything else would be guessing...
5-6 inch lift.
