Axle wrap?
I'm trying to figure out if what I am expecriencing is axle wrap or something else. I've had some drive line vibration at take off well yesterday I pulled the chip out of my truck to get it reburnt and when I drove the truck today the driveline vibration was almost gone completely upon take off, does it sound like I am experienceing axle wrap from the added power of the chip or is it something else?
i wouldnt suspect your feeling axle wrap, unless your pedalling the throttle. loading and unloading the springs is what cause wheel hop. now, during acceleration you will feel axle wrap in a sence that the trucks lifts up. the addded power could be adding enough flex to change pinion angles enough that it may have a slight vibe, i would think you would be hard pressed to notice it. i may look more towards trans shudder from time used with a tune.
i have the same or atleast similar thing happening and i know for a fact it isn't axle wrap seeing as i have traction bars. i'm pretty positive that my carrier bearing is getting weak and allowing to much movement of the drive shaft
Carrier bearing. If you have a lift you need a carrier bearing drop bracket
The truck has a leveling kit and a 3in block.
3in block by itself or on top of factory block? Im gonna assume by itself and you should be fine with out drop bracket. But carrier bearing could be worn out. Get under your truck and try to move shaft around it should barely budge
There just stock 350 block thats the only block nothing stacked on top.
I would check the carrier bearing then.
I've looked at the carrier bearing a couple times and it does move around a little but I thought it was acceptable considering its mounted in rubber the rubber around the bearing doesn't look the greatest though its showing its age it's not wripped just stress crack in it. I guess I'll replace it and see what happens
I would they are pretty inexpensive and easy to change
