Which helper bags? - Page 4 - Ford Powerstroke Diesel Forum
post #31 of 50 Old 11-28-2012, 02:55 PM
On 'why' bags, or 'which' bags? Firestone and AirLift both make brackets for lifted applications.
TexasA&M is offline
post #32 of 50 Old 11-28-2012, 05:55 PM
6.0L Stroker's Avatar
My bad guys autocorrect on the phone. Yes which bags. Do you guys suggest inboard or outboard bags? No gooseneck or fifth wheel installed.
Sent from my iPhone using AutoGuide.com App
2011 F350 CC/SB Bronze and Gold KR tinted windows, spray in bedliner. MBRP 5in filter back with 6in tip and Mini Max. S&B Dry Intake, TGC Dual Stabalizer.
Sold 2004 Ford F-350, cc/lb Lariat, Procomp 6.5 lift with 37/13.5/17 Toyo Mts, Id tuned Ficm, Bully Dog Triple Dog, MBRP all the way back,
6.0L Stroker is online now
post #33 of 50 Old 11-29-2012, 09:36 AM
OCVeloMan's Avatar
Quoted: 151 Post(s)
Garage
Originally Posted by 6.0L Stroker View Post
Guys any suggestions on which bags for my truck? It's 11 350 lifted 4.5 inches carli kit. And I have the full rear springs which eliminate the block. Sooo bags above the spring would be stretched. Carli makes bags but there 850 witt no compressor. That seems like a lot to me. I even though about those sumo springs but my bump stock distance to axle is greater too
Our bags are more expensive given their design. We utilize a tapered piston design that will not change your ride quality when deflated where the above-mentioned double-bellow bags will make the ride quality more harsh even when empty. Further, your full springs travel 12" in the rear and our bags will travel 12" as to not limit ride quality or travel. The cheaper double bellow bags will limit your travel to 4-6". Just food for thought. We're not getting rich off the bags, they're extremely expensive to produce!
OCVeloMan is offline
post #34 of 50 Old 11-29-2012, 10:39 AM
Personally, if I had already spent top dollar on a Carli lift, I would pony up and get the bags that are designed to work with the lift. You can make one of the other kits work, but you'll sacrifice performance somewhere.
I do not believe that the AirLift or Firestone bags make your ride worse when they are empty... if they technically do, it is not noticeable on my truck. With only 5lbs of pressure in them, they are easily squeezed by hand, and are doing very little (if anything) to support the truck, and therefore do not effect the ride by any noticeable account.
TexasA&M is offline
post #35 of 50 Old 11-29-2012, 12:09 PM
scparrish's Avatar
Quoted: 79 Post(s)
Feedback Score: 3 reviews
thats a lot of travel for bags impressive. I havent noticed a more harsh ride from any kind of bag when properly deflated for empty loads
White Early 2004 F250 Harley
Adrenaline hpop, Aeromotive, ARP, BPD, BTS, Carli, Fox, Fuelab, GH/TSD/Wildman, Holders 225/75, KC Turbo, PMF, S&B, Mishimoto rad/ic, 08 axle swap
scparrish is offline
post #36 of 50 Old 11-29-2012, 01:57 PM
I fully understand what your saying and in all honestly I will probably go with your guys bags anyway because I know it will work. And work right. Thanks the info also! Ill be ill be calling George soon for them.
post #37 of 50 Old 03-14-2013, 02:48 PM Thread Starter
TxFireman1972's Avatar
Feedback Score: 6 reviews
Bumping it back up. My airbags are on, just need to get a compressor and maybe a tank ordered. I may just order a simple compressor for now, and new a more elaborate setup later.
Any suggestions on a simple compressor just for airing the bags up?
2005 F350 Crew Cab 4x4
PMF Rear Leaf Spring Conversion w/2011 Leaf Springs
20" Harley Wheels 305/55/20 Nitto Terra Grapplers
ARP Studs & EGR Delete from PowerStrokeMagic w/GearHead Tunes
Amp Research Steps, MBRP
"Two in the heart, and one in the head, I don't like repeat offenders, I like dead offenders!" -- Ted Nugent
TxFireman1972 is offline
post #38 of 50 Old 03-14-2013, 03:22 PM
banshee-rider's Avatar
Quoted: 7 Post(s)
Garage
A little off topic but did you ever put the icon shock kit on?
2005 FORD F250 CREWCAB LARIAT
9 INCH LIFT
37x13.50x20 TOYO M/T'S
PMF TRACTION BLOCKS AND BARS
MBRP 4 INCH TURBO BACK
ARP'S,STAND PIPE'S, DUMMY PLUGS ALL THE UPDATES
SCT LIVEWIRE SRLxx
2008 SUPERDUTY TAILLIGHTS
OPT7 LED HEADLIGHTS AND FOG'S, 50 INCH LED BAR
AMP RESEARCH POWER STEP'S
AIR BAG'S TRAIN HORNS AND AIR COMPRESSOR
CUSTOM STEREO
XDP COOLANT FILTER
PSC HYDRAULIC ASSIST STEERING
RCD EGR DELETE
EXCURSION CENTER CONSOLE
2007 REAR VIEW MIRROR AND MIRROR SWITCH UPGRADE
banshee-rider is offline
post #39 of 50 Old 03-14-2013, 03:25 PM Thread Starter
Which ones? lol
I'm on stockers right now
post #40 of 50 Old 03-14-2013, 03:29 PM
Quoted: 7 Post(s)
Garage
I thought you were having stock height icon shocks being built with piggy back resi's
9 INCH LIFT
SCT LIVEWIRE SRLxx
CUSTOM STEREO
XDP COOLANT FILTER
RCD EGR DELETE
