look at the rear axle and measure the block a stock 250 will have a 2inch block with a bump stop .. if there is another block or a taller one then measure that to see what size lift
your image isn't good enough for Me to tell if it's a level kit or lift if any |
PS the axle sticking out is an issue are you sure the frame is ok
typically when u lift a truck it shifts the axle to the driver side unless u put a drop trac bracket or adjustable trac bar in to correct Last edited by ZMANN; 11-16-2012 at 06:36 AM. |
Okay thanks ill check that when I get home. It did have a little frame damage but it was fixed so it may be the track bar
it helps me see the front fender trim is only black on one side of the truck LOL are those cut out flares ? that is messing with my perspective on the truck Height
Sorry I don't hang around stock trucks enough to tell by looking |
the black lower paint is also messing with my perspective
you could probably find a stocker to measure just measure from the axle center to wheel well top that will negate the tire size from affecting the # |
Haha yeah I bought pocket style fender flares and they sent the wrong ones for the front.
And motorboy they are 275/65R20s
