What next? - Ford Powerstroke Diesel Forum
Old 11-15-2012, 02:21 AM
What next?
My 04 f-350 6.0 with 125,000 miles was swaying a little going down the highway. I am having the left and right upper and lower balljoints replaced. Also replacing both front sway bar links and bushings and new front shocks. Also having it aligned. Is there anything else suspension wise I should consider?
Old 11-16-2012, 09:39 AM
Check the bearings while it's all apart. Although I would be looking at shocks and sway bar links if it were mine.
Are you replacing ball joints because they're worn? If they're not bad why spend the $?
sent from a dumb guy with a smart phone
