Question on rear air bags - Ford Powerstroke Diesel Forum
post #1 of 14 Old 11-03-2012, 07:49 PM Thread Starter
I installed a 3.5" ready lift on my f350 with a 5" rear block. Currently I also have a 1" aal in the rear with the block. I also put new 35" duratracs and bilsteins all around at the same time. My rear bounces at 50 mph and don't think it my tires since they've been balanced 3 times and still the same. My dad has the same truck and I'm going to swap the rear tires (his are still stock) to see if it bounces or not. If it does then I'm assuming its the aal. If not then its easy and it's the tires.
I wish my rear sat up another inch so, instead of 2" of total lift in the rear I'd like 3". However, I have a black truck and need to be able to wash it in the car wash about once a week and right now it barely fits. If I lift it any more I think my cab lights would hit the dryers.
Here's what I'm thinking if its the aal that's the problem...since I have over 1000ftlbs at the rears I want to get a set of fat boy traction bars to help with eliminating axle wrap. I was thinking about getting 5"-6" blocks with the traction bars and taking the aal off and installing some air bags. This way I could deflate the air bags when going through a car wash and then inflate them back up when I get out to the rake that i want. I think the aal is just making my one ton ride too rough.
Sounds like it would work to me, what do you think? Do bags ride softer than aals? Can I get 2" of rise with bags and which should I go with?
blk450er is offline
post #2 of 14 Old 11-04-2012, 07:06 AM
shawnb99's Avatar
you will be highly disappointed in the ride with inflated bags, and no load. the bouncing as could be tires, but if they balance out, the shocks could be junk, they are what controls spring activity. if you do have that kind of torque, a traction bar will help, but a full replacement leaf would be better.
04 F-250 CCSB 4X4 6.0L Auto, tweaked by GEARHEAD
follow link to truck for sale
shawnb99 is offline
post #3 of 14 Old 11-04-2012, 12:55 PM Thread Starter
Just talked to a guy at church today with the same duratracs and he said he has the same bounce at 65 and can't get it to go away
blk450er is offline
post #4 of 14 Old 11-04-2012, 03:43 PM
shawnb99's Avatar
are you sure it isnt your roads, i have a few in the area where you can watch all trucks bounce for a while
shawnb99 is offline
post #5 of 14 Old 11-04-2012, 05:22 PM Thread Starter
Does it on all roads. Brand new asphalt, concrete highway, old back roads ect. If I'm doing 50, then it's bouncing. It's not a bad shake your truck loose bounce, just an annoying fast bounce. I kinda ruled out the tires since every time discount tire said it balanced at zero. But it feels just like out of balance tires
blk450er is offline
post #6 of 14 Old 11-06-2012, 02:26 AM
You running emulsion shocks in the rear? They might not keep up to the spring rate of your rear leafs?
2004 F350 PSD
8" Icon, Loud Pipe, 58v FICM, Deleted, MudGrapplers, Edge Insight, Sct tuned by Vivian.
2011 F350 PSD
AFE , Airbags, Recon, BMF , Nitto,
20046.0 is offline
post #7 of 14 Old 11-06-2012, 09:47 AM Thread Starter
Um don't know what emulsion shocks are. I agent to the car wash last night and had them stop my cab lights under the dryers which is the lowest point so I can measure for sure. I have 3.5" between the lights and the dryer. I'm getting 7" blocks with my fat boy bars and eliminating the aal.
blk450er is offline
post #8 of 14 Old 11-06-2012, 11:01 AM
897.3alltheway!'s Avatar
Quoted: 13 Post(s)
airbags with no load will make the ride worse, get rid of the aal and get the traction, also are your tires over filled?
i have a 6" block lift on the rear of my 89, don't get Axel wrap cause there all welded together and too the rear end, 7" block im not sure about
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #9 of 14 Old 11-06-2012, 11:11 AM
ZMANN's Avatar
Quoted: 1900 Post(s)
7 inch blocks are not a good choice IMHO
emulsion shocks ? that term is almost never used ,, specially not on these Forums
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #10 of 14 Old 11-06-2012, 02:17 PM Thread Starter
What's wrong with 7" blocks? That's the height I'd like, and have no need for the aal anymore. It'll have the same basic rake as it did stock by raising a total of 3.5" front and 3" in the rear. Actually it'll have 1/2" less rake.
blk450er is offline
