Rear block question - Ford Powerstroke Diesel Forum
Old 10-30-2012, 06:18 PM
Rear block question
Ordered leveling kit from PMF (Trevor is great guy to deal with ) I ended up getting 4.5" FLAT rear blocks per trevor. My truck is 2010 f250 supercab short bed, are these the right blocks? After doing more research I think I should of got the tapered since i have the one piece drive shaft?
Old 10-31-2012, 07:07 AM
do you have a cv joint at the t-case?
Old 10-31-2012, 07:12 AM
The 4.5" block will only lift your truck about an inch beyond an F 350 of the same cab and bed configuration, and you have a relatively long driveshaft, so you will be good, even jeeps will tolerate a 1" lift without any pinion angle changes.
Old 10-31-2012, 11:10 AM
You are right at the borderline between flat and tapered. I think the tapered would be a little too much for your application. The stock F-350 blocks which are 3.5 or 4" are flat. If you have any trouble with those, I would be happy to swap them out for you.
Old 10-31-2012, 11:16 AM
Slacker
Feedback Score: 4 reviews
Can't beat that! Trevor = GREAT guy to deal with!
Old 10-31-2012, 01:10 PM
Thanks Trevor your the man!! To everyone PMF is the best company I ever dealt with! top customer service , so pumped to get my stuff!!
