Replaces AM steering stabilizer 3x last 8 months - Ford Powerstroke Diesel Forum
Old 10-15-2012, 08:14 AM
Sic2Fiddy
I have an 08 f250 with 6 inch pro comp lift, pretty basic lift. Stock trac bars with the extenders. 37 inch tires. I have now replaced my pro comp steering stabilizer 3 times and no one seems to know why teu are going out so fast.. What do you all think?
Old 10-15-2012, 08:22 AM
How does the truck drive without them?
Old 10-15-2012, 08:27 AM
Sic2Fiddy
Death wobble when hit a bump and even during braking sometimes.
Old 10-15-2012, 08:52 AM
I think you definitely have something else going on. You might want to go through the front end. Have you had an alignment done lately? Might want to check out the track rod out too. Have your friend turn the wheel and you watch everything. Then might be worth it to just jack up the front end and do the wiggle test to see if anything is loose. Ball joints, wheel bearings, steering components, track rod, etc etc...
Old 10-15-2012, 08:54 AM
The alignment can check to see what the castor is set at...
Death wobble before lift? Or just after?
Old 11-17-2012, 05:06 PM
I had really bad luck with all my pro comp shocks on my 150 . I switched to bilsteins and never had a problem again
Old 11-18-2012, 05:46 AM
If the truck death wobbles without a stabilizer then the stab is working overtime trying to calm down the oscillation. This leads to its untimely death. A better stabilzer like a Bilstein will work better but you are just putting a bigger band aid on a gun shot would. You need to fix the under lying problem first.
