rear 4 link - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-05-2012, 06:55 PM Thread Starter
JD_MILLS's Avatar
rear 4 link
anyone have a 4 link on the rear of there truck? i'm wanting to put coil overs all the way around or air bags haven't decided yet. pictures would be great thanks for any and all help.
2008 f-250 LARIAT, SCT LIVEWIRE, S&B CAI, 8" MBRP STACK
JD_MILLS is offline
post #2 of 6 Old 10-06-2012, 07:39 AM
jetjock15's Avatar
Quoted: 110 Post(s)
There are some kits out there, check eBay you'll see the one that's always on there. There is a few kits at SEMA every year but never really catch on with the mainstream. Believe me I've considered it multiple times, but in the end I conclude its not the best route for my needs because I tow heavy, and you just can't beat the reliabilty of leafs, and you can't get coils with as much progression as you can leafs. If you want a show type truck I would go for it. For pure performance leafs can do just as good. I've had a custom set built that and reworked over and over to get then right. Now works perfect, tows, has 18" of travel. Good luck.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #3 of 6 Old 10-06-2012, 11:02 AM
897.3alltheway!'s Avatar
Quoted: 11 Post(s)
ya ur truck is junk without rear leafs cause those coils will just fall on there face when it comes to towing
show truck^ yes coils are fine but for towing heavy laods for what ever reason then no, but for show yes!
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #4 of 6 Old 10-06-2012, 08:51 PM Thread Starter
JD_MILLS's Avatar
This truck is strictly my toy. the heaviest thing it sees is a 8 ft trailer with my motorcycle or 4 wheeler. my main thing is i want a softer ride and more suspension travel. i've talked my self out of the air bags but still considering coil over or may just put some light atlas springs and some bilsteins.
JD_MILLS is offline
post #5 of 6 Old 10-06-2012, 09:16 PM
Quoted: 11 Post(s)
oh, well ya coils will do fine with that and the ride, ya u will get more travel with the springs then leafs
-Jeremy
Got A Few Rides...
post #6 of 6 Old 10-13-2012, 10:42 PM
Deaver Springs
Lots of pre-runners still run leafs in the rear (64" deaver springs) The pro units run 4-link but still. Leafs rock.
2004 F350 PSD
8" Icon, Loud Pipe, 58v FICM, Deleted, MudGrapplers, Edge Insight, Sct tuned by Vivian.
2011 F350 PSD
AFE , Airbags, Recon, BMF , Nitto,
20046.0 is offline
