Prefered alignment specs for stock height
I have an 04 Ex with 43k miles on it. It has been suffering from wandering. I had it aligned and lowered the tire pressure to stock and it helped a little but still wanders. I snugged down the steering box bolt a little to take up the freeplay in the wheel. I forgot to ask for a printout but I'm sure it was aligned to Ford spec. I'm going to head back and wanted to know what the optimal alignment specs are for a stock height truck. All the front end components are tight so I want to rule out the alignment before I do a steering box. Thanks.
What tires, and size are you running? Stock tires with hard wear and no tire rotation could contribute....just a little more info could help find your answer.
KVB |
i belive a good start for a solid axle truck is 4* positive caster, top balljoint layed back from the lower..... pinion angle slightly down, as far as toe, i try to set them at 1/8 to 1/4 toe out.
265/75-16 Firestone Transforce HT with about 500 miles on them.
Toe out and not toe in? Does it track better?
some may argue, about this one.... when force is applied , the suspension tends to toe out . but a setting of toe in will make the vehicle tend to dive hard into the turn, the steering can be a little too responsive , i have have always prefered the negative feeling of a slight toe out setting. this is also a way to help control deathwobble per say. when a tire hits a hole or bump and want s to wander , it now has to pull the other tire past center , this i feel achieves the control, whereas if you tire is centered or toe in, it is ready to go that direction, this can make a vehicle very unsafe. you hit bump, vehicle instantly dives that direction, and your ability to control or more so over compensate, causes bad situations.
Their is nothing you can do with the alinement of a Excursion to fix the handling issues..the springs are the main problem as the fronts are not rated for a diesel and the rears are just crap. We have helped thousands fix the excursion handling issues.. PM me if I can help your's.
Cary |
