Go Back   Ford Powerstroke Diesel Forum > General Topics > Suspension & Steering
Old 10-19-2007, 09:41 PM
eazenutz33 eazenutz33 is offline
Send a message via AIM to eazenutz33
small lift......for eventual tires and maybe wheels....programmer??
I have an 05 F250
I'm wanting a 2-3" lift front and back, nothing extreme, just a lil more clearance and I'm wanting to get a lil bit bigger tires once my stock Bridgestones start to wear out......bout the same time I might have money for new tires(their fairly new)! If I have the money then, I might try to get a set of 20's or 22's for it with rubber, but not planning on it yet nor planning on anything real radically big, more than likely money will be tight once again.
Anyone have any suggestions to give a small lift for an 05? I've heard their a pain compared to 04's and earlier. My buddy has an 03 7.3L Excursion and made his own 8" lift, and was the one who let me know its a pain on 05's and up. He also used F350 springs on his 03....does that lift it anymore???
Got exhaust and an intake waiting to be installed, but was warned against getting a programmer.....anyone have any info on this too? I drive it mostly on the highway to and from class, a little bit on the farm checking cattle, and of course its going to be used to shoot deer out of when it gets too cold! I've been told to expect up to 15% economy increase with just the exhaust and intake driving it the way I do, rather calmly and well within the speed limits. I've been averaging around 18.5mpg using diesel kleen, zoodad mod, and diesel from murphy oil (walmarts gas station).......I filled up at a Phillips 66 and it dropped to 14.5 mpg tho!!!!! Learned my lesson and they can keep their diesel!!!!
Thanks a ton, I know its a long red and a lot of stuff, I'm just gettin back into having a truck again after 6+ years driving a chevy car(not sure what I was thinking!). Not to mention its my first diesel.
Old 10-19-2007, 10:03 PM
2005F250 2005F250 is offline
I got the bilstein leveling kit and it is sweet. 1000x better ride and took about 3 hours to put it on. It also sells for a good price.
Old 10-20-2007, 05:13 AM
i'm prolly understanding it wrong, but doesn't that just raise the front of the back??? I was thinking it raised the front about 2" or so. If the entire body lifts I wouldn't mind that!
Old 10-20-2007, 09:59 AM
Raul@Stealth Automotive Raul@Stealth Automotive is offline
it will just lift the front... most leveling kits will only lift the front... easiest and cheapest leveling kit you can get for your truck is just a simple coil spacer
Old 10-20-2007, 11:50 AM
Stroker49 Stroker49 is offline
leveling kit
i'm not trying to jack his thread, but can i put on a leveling kit and a 2-3 inch lift. I'm kinda like him i want a lift, nothing to hateful just enough to clear 33 or 35's. preferably 35's. I'm really unfamiliar with raising trucks so any help is genuinely helpful
Old 10-20-2007, 12:21 PM
Dave Dave is offline
Obama sucks
leveling kit will clear 33's 35 will rub a little at full lock
Old 10-20-2007, 12:35 PM
No they won't. As long as you don't mess with the caster. With the right wheels you can put 37's on a leveled superduty.
Old 10-20-2007, 12:38 PM
Obama sucks
Thats true if you have a different offset wheel about the 35's not rubbing but on stock wheels my bros buddys truck with 35's rubs
If you have a 99-04 and want 35's with a leveling kit it is easiest if you use 16" wheels. If you have a 05-07 with a leveling kit like mine you can easily put 35's with any size wheel. If you want to put 37's your going to need to do some research.
Old 10-20-2007, 12:40 PM
It does rub and I just remembered that I just cut part of my fender liner to stop the noise. The tire won't hit body panels as long as you don't mess with the caster. I did that and wouldn't recommend doing it.
