14-16in lift help
Anyone have any experience with doing a leaf spring lift and adding spring hangers to get more out of it. To be specific 8 rough country with 6in spring hangers? The good the bad stuff that has to be changed anything will help.
you will need address steering / track bar angles and lengths. driveline lengths and angles, probably something along the lines of hydro assist steering, brakelines....ect. contact PMF ( trevor ) he seems to be knowledgeable in large lifts on superduties
You will need:
longer brake lines longer shocks 6" shackle and hanger kit Index ring and crossmember crossover steering crossover trackbar kit hydro assist (recommended) rear traction block kit (recommended) one piece rear drive shaft (high angle CV recommended) We have all of the above components except the drive shaft and brake lines. |
Thanks for the help y'all, and notstock is there a specific place to get all those extras or does like 4wheelparts.com have all that?
Driveshaft you will want a good local shop to do it with the truck in front of them. Brake lines, I would recommend Crown.
Ok and how much is all the components y'all carry?
