So Im planning on doing a SAS with a Dana 60 into my truck in the next few weeks. Problem though making it a bit more complicated is I already have (I believe) is a 6" lift on my truck currently. The measurement on the front shocks eye to eye is right around 21". I was told this is a 6" lift, is that correct?
My initial intention was to go cheap for now and use my current front lift springs and just toss the 60 under it and call it good, for now. But there is a part Id need in the RSK from Sky that Id have to purchase separately, if I bite the bullet and do the whole kit now, itd save me that much money in the long run.
More to the point, this is the kit I'm looking at.
92-97 Ford OBS Super Duty Leaf Conversion Shackle - Sky's Off-road Design
Its the *newer* kit they have specifically designed for SD springs. My main question is-- am I going to need just regular stock SD springs to keep my truck level with the current lift in the back, or would a pair of SD leveling springs make it level? Im thinking if the kit only adds 4" of lift, SD front leveling springs would make it sit about perfect front/rear and I wont have to touch the rear setup. Thats my goal. Maybe down the road I can look at trying to put rear SD springs in it to finish it off, but my budget is tight right now. I have a source to get either stock SD springs or leveling springs for the front for 100 bucks a pair, used. Something that makes it more confusing is Ive heard that just putting the D60 in without changing anything else can add up to 1"-1 1/2" of lift just that alone. Is that true?
Any one do this kit yet and can offer advice? I called Sky and didnt get any more info other than "it adds about 4" of lift, my kids designed it that way, and its built around the stock SD springs" --Basically what was already advertised online. Im looking at this kit rather than their older kit as it looks like it doesnt require to modify the frame horns to go to super duty springs. (the guy I spoke with at sky wasnt even sure if this was required or not) While I have the skills to do that, I dont have a welder and a torch. This kit looks primarily bolt on, other than drilling a few holes, and a small possibility of notching the bumper.
What could help out is getting ride height measurements from someone who has installed this kit on their truck. True size of tires, shock measurement from eye to eye, measurement to bottom of front frame horn, measurement to body line that runs horizontal... and anything else that might be pertinent...
So, do I really have a 6" lift? Would stock or leveling SD springs put me at level with my current suspension in the rear? Does just the D60 add lift by itself alone? Does this kit require modifying the frame horns?
Thanks
