Fox Suspsion for 1994 F-350 - Ford Powerstroke Diesel Forum
Old 08-04-2012, 07:53 PM
I am wondering if anybody knows if i can put Fox on my pickup.
Old 08-05-2012, 05:46 AM
stock height or lifted ????? you can put what evr you want on there, what will dictate the endeavor is the needed shaock lenght. IF you are referring to a RES. shock, i dont believe fox makes a short body for stock or leveled applications. BILSTEIN makes a few shorter sizes. take a measurement of the stock shock, and try to mimic it with whatever your choice is..... you will need to measure body length, extended and collapsed.
Old 08-05-2012, 07:40 AM
Like shawn stated you almost put any component on your truck. You will have a better chance of lifting your truck 4+ inches to get those fancy shocks you see on the interwebs.
Old 08-06-2012, 11:34 AM
Feedback Score: 5 reviews
No problem...I would suggest Bilsteins as a better cost effective option. Either way we can get both
Old 08-06-2012, 08:07 PM
Thank You the help. I do alot of towing and some off 4x4. i want a smother ride. is there a specific bilstein shock that will work the best
Old 08-07-2012, 02:37 AM
best bet would be the 7100 series. they offer a short body maller amount of travel and they are tuneable to your springs. they arent very expensive for the reward. of course there is numrous other shocks, makers and toher variables. but right off top, this would be my first option.
Old 08-07-2012, 05:10 AM
#7100 won't bolt up to the rear without new mounts and no shock will help smooth the ride of a OBS with stock springs. If your looking for the best ride possible its easy..
I developed the mod for using SD springs and a RS kit 11-12 years ago and have helped thousands perform this mod. It will transform a OBS trucks ride. Actually will ride better than any stock SD
We also developed the 99-10 axle swaps with suspension for the OBS.
pM me if you would like more info.
Old 08-07-2012, 08:19 AM
yes i am intrested in any thing that will help me smooth it out
