Go Back   Ford Powerstroke Diesel Forum > General Topics > Suspension & Steering
Old 10-12-2007, 03:58 AM
panteramatt panteramatt is offline
inexpensive lift???
I want a 4" lift on my diesel 2000 f250 4x4 and was wondering whats the cheapest way of going towards it. I dont want a body lift and Ill probally be using bilstein shocks. I just wanna fit 35's on there.
Old 10-12-2007, 04:25 AM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
Get a quality lift kit. Most of the popular brands, like rancho, sky jacker, super lift, donahoe racing, pro comp, fab tech, tuff country, are all basically the same but they all have there differences. Just shop around for the cheapest and best deal.
Old 10-12-2007, 05:09 AM
Lonno Lonno is offline
Check out the site sponsors, if you can do the work yourself, I bet you can get one pretty cheap. Probably a pro comp or fabtech 4" if you just want to fit 35's.
Old 10-12-2007, 05:35 AM
dustindiesel dustindiesel is offline
cheapest way and you will keep factory ride quality is to get a set of 4" shackles for the front a put a block in the rear. you still need shocks but the whole thing would be way cheaper than springs
Old 10-12-2007, 05:50 AM
cj41foley cj41foley is offline
I'd just put a leveling kit on the front if I was only going with 35's, I've seen it done a million times
Old 11-09-2007, 08:25 AM
What about a set of add-a-leafs for the front and rear and a set of 2" shackles for the front?
Old 11-09-2007, 08:28 AM
Raul@Stealth Automotive Raul@Stealth Automotive is online now
cheapest would be a pro comp 4" kit.... you can do an add a leaf then shackles but you would then need longer shocks and a trac bar bracket... once you get all those stuff separate your going to be paying around the same amount or barely less than just buying a full susp system
Old 11-16-2007, 05:35 PM
powerstrokin87 powerstrokin87 is offline
Send a message via MSN to powerstrokin87
i have a trailmaster 3" leveling kit in the front with an addaleaf, plus a procomp track bar bracket and drop pitman arm. in the back i took out the factory blocks and replaced them with one 5" block all in all its about a 4-5 lift but after all the aggrivation and looking back i wish i woulda saved my money and just bought a lift KIT. not pieced it together but it works.
Old 11-16-2007, 06:17 PM
crash6882 crash6882 is offline
where do you get the 4" shackles for the front too?
Old 11-16-2007, 06:19 PM
FORDRARY FORDRARY is offline
i got my 4" lift on ebay for about $600
