2001 F250 U Bolt Dimensions - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-26-2012, 07:38 AM Thread Starter
I'm going from a lift back to factory suspension and need new u bolts. I have a local spring shop that can make me the bolts, but they need the dimensions obviously. For the front I have found that stock they are 9/16 x 3 1/4 x 10 1/2, is that right ? FYI I'm 4WD and do have he aux spring in the rear. For rear u bolts with the stock 2" block I've found 5/8 x 3 5/8 x 13 1/2, is this right? Judging by what I have now, both front and rear are round ?
I've searched high and low and couldn't find a definite answer on this. Thanks.
Jmunk is offline
post #2 of 5 Old 07-26-2012, 07:47 AM
ZMANN's Avatar
Quoted: 1911 Post(s)
bump
I know the 3 5/8 is right for the rear because I just had some made ,, but the rest on the dimensions you should be able to figure out just by measuring and doing the math ?
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #3 of 5 Old 07-26-2012, 05:29 PM Thread Starter
I got the measurements I needed, here are the stock U bolt dimesnsions:
Rear: 5/8 x 3 5/8 x 13 1/2 Round
Front: 9/16 x 3 x 9 1/2 Semi-round
Front U-Bolt part # through Husky is UA168C, they are around $6.00 each with nuts and washers on Rockauto. Rear U-Bolt part # through Husky is UA207R, cost at Rockauto is about $12.00 each. I'm getting all new U bolts for front and rear for close to $60.00 which I feel is a good price.
Jmunk is offline
post #4 of 5 Old 07-26-2012, 05:32 PM
ZMANN's Avatar
that is cheap you did good
I paid $50 to my local shop for 4 rears 13 inch with nuts and washers
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #5 of 5 Old 07-26-2012, 05:35 PM Thread Starter
Local spring shop wanted $16 each which comes out to $128, which I thought was high. The dealer wanted $16 each as well, but didn't stock them. I thought that since u bolts are suppose to be a one time use that the dealer would stock them. Husky is a decent brand name. Hopefully others will be able to use my research, also I located a coupon code for Rockauto for 5% off.
Jmunk is offline
