Excursion Wheel Hub Bearing Assembly Part Number
I need an accurate Ford Excursion Wheel Hub Bearing Assembly Part Number. I figured I would just replace about everything on the front end since it will be apart and the previous owners were running over sized tires. My problem is that I am seeing two different part numbers listed for a 2003 Ford Excursion.
if you have 14x1.5MM Lugs or the part that is listed on SuperdutyPSD.com if you have 14x2MM Lugs From the research I have done, I believe the above information to be accurate. Timken Automotive Product Catalog 1990+ Last edited by Brew_WY; 07-25-2012 at 06:55 PM. Reason: Added more information. |
Thought I would bump this since I added information to the original post.
Cheers, Brew |
