Go Back   Ford Powerstroke Diesel Forum > General Topics > Suspension & Steering
Old 10-10-2007, 11:47 AM
dcs191919 dcs191919 is offline
What size tires+ lift
I want to get a lift and bigger tires for my 06 king ranch 6.0 4x4. Currently it has 305/65/18 can I go any bigger than that stock? What lift will fit 35's. I would prefer 4 inch lift? What is a good lift that isnt to pricey? Also I was thinking about running the 35" toyo open country MT's. Thanks,
Old 10-10-2007, 11:52 AM
Redneck47441 Redneck47441 is offline
revtech 4.5" is a good one with 35's
Old 10-10-2007, 11:54 AM
Raul@Stealth Automotive Raul@Stealth Automotive is offline
you can prob fit 35" tires with a leveling kit... but a 4" lift kit will def clear 35's as far as lifts DR being the most expensive but best kit.... a simple coil spacer will be around 150 bucks shipped...
Old 10-10-2007, 12:17 PM
can I run those spacers with my fx4 rancho shocks? Also I just got this truck I was wondering if you guys know if those camper tops are heavy. I might take it off..
Old 10-10-2007, 01:36 PM
yup you can use your shocks... only goes up 2" in the front.... here is the link to them Pro-Comp 2.5" Spacer Poly Lift Kit
Old 10-10-2007, 09:10 PM
Sweet thanks for the link..I barely clear the airport parking lot right now.. So I guess after tires and leveling kit I cant park underground
