4 link vs adjustable link arms - Ford Powerstroke Diesel Forum
Old 07-07-2012, 08:35 AM
So im looking at one of these options for the front of my truck. Right now i have an 8" icon lift, 2.0 icon monotube shocks and dual steering stabilizer with bilstein shocks. Im looking to improve my ride, improve handling and tighten up steering feeling. What are the advantages of both? While searching i saw a bunch of prople who said the wanted the ala's but already had the 4 link or it was on order. So this leads me to believe that the 3 link may be more desireable. I dont want a brand battle (ouo vs pmf) but why doesnt ouo make a 4 link? Pmf makes both? My truck is 95% street driven, tow occassionally and just built for a good time(no rock crawling, high speed desert racing or deep mudding). So if i can get opinions on both and feedback on both that would be great
Old 07-07-2012, 08:46 AM
I have heard comments from people with various 4 link kits that you can feel the sway
where as the solid radius or 3 link does not have side ways flex
I am leaning towards the 3 link to loose my stockers
also PMF told ME He didn't know if the 4 link would work with an 8 inch lift ? not sure why We didn't discuss it in depth
also on the steering note almost all the fords I have driven could use some steering gear adjustments
Old 07-07-2012, 09:00 AM
I was leaning towards the 3 also but when talking to trevor he said he suggest a 4 for anything over 6". Now im confused.
Old 07-07-2012, 09:06 AM
Well I just reread the Email
it's the 3 links that are maxed out at 6-7 inches I was going to Buy Chris Corbin's
so I hit trever up
sorry bout the confusion
I still wonder if the 3 links will work with a drop radius bracket ? We both already have them ,, the 3 link is cool because you can dial the axle camber in the 4 links just add keeping the axle angel the same through it's travel ,, at least thats my take
Old 07-07-2012, 09:14 AM
Glad we git that clear. I asked him about the use of a radius arm drop bracket but havent heard back. Will update when i do. According to ouo you can use a drop bracket for lifts over 6" with their kit.
Old 07-07-2012, 10:44 AM
Yes, you certainly could use a drop bracket with a 3-link setup. We havent built any in the past but I could design some if you wanted. It would require the removal of your stock radius arm mount on the frame which is a large task by itself as these are held in place with 10ish hot rivets, some on the inside of the bracket. An air chiesel would be needed to do so. I typically recommend a 4-link on the larger lift heights.
Old 07-07-2012, 11:35 AM
I got a 7" and PMF's 3 link and they work great and look killer! I would do the 3 link!
Old 07-07-2012, 12:35 PM
I couldnt just bolt the 3 link to the icon drop bracket. The 3 link is supposed to replace the radius arms so it makes sense it would just bolt up. Its your product so you know best, im just trying to understand. Thanks
Old 07-07-2012, 02:19 PM
thats what I am thinking
u can use a pre existing drop bracket that would have been for a stock radius arm to implement the 3 link for a lift over 8 inches and did not require the removal of the stock unit .. I will have to go take some pics
Need a test truck PMF ;-)
Old 07-07-2012, 03:08 PM
maybe i am mistaken , but i have yet to see a three link in this post. what is see is an adjustable RADIUS ARM setup.
my take is a four link will allow for better articulation, with less binding.
if you want high speed off terrain , go radius arm, it allows more travel with more of an actual arc motion, the 4 link is constantly changing caster.
if you look at the CARLI radius arms, they tried to conquer both worlds, by adding a dampner to one side to allow for some articulation, with out bind.
