Swapping Suspesion from 4 inch all suspension to stock with leveling kit.
I was just wanting to know how hard it is to take out a 4 inch suspension lift and go back to stock height with a leveling kit. I didnt know if someone could tell me what all i would need to do the swap. I didnt know if someone had done it and could tell me how hard it is to do. i have access to a two post truck lift and all the tools you would need, i just didnt know what parts i need. Thanks!
Id find someone who would trade you suspensions. Work on the trucks side my side and swap everything from one to the other
Sent from my DROID3 |
Ditto...I'd do it, but I'm sure your not in Alaska.
Same here, but he's not in washington either
ok thanks and yea im in Indiana, what all will i have to take off? im new to lifts and suspension stuff. can someone put up a write up of the parts i would need and whats a good leveling kit?
It all depends on how the lift was achieved. Without knowing or seeing the truck in question, only assumptions can be made.
Regardless of the method of lift, one can only hope a drop tracbar bracket, drop pitman arm, and adjustable tracbar were used. Those will need to come out. OEM tracbar bracket and OEM pitman arm will need to go back on. The tracbar might be able to be reused. Socks will likely need to be replaced with shorter ones. If it is a spring lift, then you will need to remove the leaf pack and replace with stock and then use whichever 'leveling kit' you want to go with. If it is a hanger/shackle lift, then a stock version is required and then the method of 'leveling kit', or use a 2" hanger/shackle kit. If blocks were used to lift the rear, then those need to be replaced with stock. Way too many variables to tell exactly what it needed. |
Many manufacturers only utlize a track bar drop and drop pitman arm on a 5" lift or taller given the stock mounting locations are ok up to about 4.5" of lift and allow for max travel but can cause bind over 4" if not engineered properly. Depending on the manufacturer, you're looking at: Add-a-Pack/Front Block (Could be a spacer instead) Taller Shocks Track Bar Drop (possibly) Exended Length Track bar in Stock location (If Icon or Carli) Drop Ptiman Arm (possibly) Longer Sway Bar End Links or Sway Bar Drop Bracket Radius Arm Drop Bracket Brake lin/ABS Extension Brackets Rear Blocks and U-Bolts/Rear replacement Spring pack Taller Rear Shocks E-Brake line relocation Bracket Carier Bearing Drop Bracket As stated by beta racer, there are many variable as no one builds the same kits and lift is achieved by many different means. It may be better to have a professional handle it if you're new to susepnsion work. |
ok thanks for all the help guys ill be looking in to how they achieved my lift
