Leveling kit installed, now a couple of questions - Ford Powerstroke Diesel Forum
Old 06-25-2012, 04:43 PM
Just finished the install of a Readylift SST 2.5" leveling kit (part # 66-2515, the one with the track bar relocation bracket and carrier bearing spacer). The job went pretty smoothly and the truck drives great and tracks straight now that I'm complete. Nothing binds, nothing is loose, drives just like it did before.
I have two questions, probably just me being anal, but some differences I "think" I noted now that the install is done. The installation is pretty simple; hard to screw anything up if you've got the springs indexed in correctly I would imagine, but just to be sure...
1. Although the kit has the track bar relocation bracket, my axle seems to be pulled about 1/4" - 1/2" to the driver's side when viewed from underneath. The gap between the spring and the frame is only about 1/2" on the passenger side, while it's right around 1" on the driver's side. You can tell that the bump stops are lined up a little bit differently on the axle now as well. When looking at the truck from the front, neither of the tires appears to "stick out" more than the other.
2. The shock and spring don't seem to line up parallel with the spring/shock mount on either side any longer. They're off by a slight angle. I seem to remember both running parallel with the vertical edges of the spring/shock mount before the kit was installed.
Anything to be concerned about?
Thanks!
Old 06-25-2012, 05:49 PM
interesting
Old 06-25-2012, 07:16 PM
you should be able to center the axle with the track bar.... if it is adjustable ? if not the bracket with the kit isnt exactly rite, but no harm if everything clears. as far as the axle being back slightly, the factory radius arms with continue to pull back the farther you lift it.... it is just simple geometry....if your tires clear everything, drive it. but the addition of a level kit with just a spacer wont make it any easier to get a larger tire on it. they will rub worse with the lift than with out.
Old 06-26-2012, 05:41 PM
I guess the bracket is not necessarily a one-size-fits-all solution, but as you said should be good enough I imagine. Track bar is not adjustable.
No need for a larger tire... I just upsized from the factory 18" wheels to the factory 20". Didn't need a leveling kit, but it looks so much more "right" than it did from the factory.
Thanks!
